Ambac PSB 6 Injector pump
Scupper
11-29-2006 09:16:58
Does anyone have an idea where to find a manual for this pump? So far, the internet search has come up empty, and my local dealer has been unable to help. Thanks in advance!
J Schwiebert
11-29-2006 14:21:36
 Re: Ambac PSB 6 Injector pump in reply to Scupper, 11-29-2006 09:16:58
What is the (are ) the questions you are having? It is a PSBwhat. Please fill in the rest of the model number.
Scupper
11-29-2006 16:53:18
 Re: Ambac PSB 6 Injector pump in reply to J Schwiebert, 11-29-2006 14:21:36
Its a PSB6A-75C-3411A, on a 1954 Case 500D. I'm in the process of reworking it, just put new sleeves and rings in, valve job, etc. I really don't have a reason to believe there's a problem with the pump, because the tractor ran before, except for very low compression, with lots of blue smoke. I have the parts and maintenance manuals, and just want to get smart on the pump also, just in case. Part of the fun, since this is my first diesel. There is what appears to be a small allen screw on the right side of the injector pump head with no cover on it that seems to be loose. Should it be tight, or have a cap over it? Appreciate any info you can provide.
J Schwiebert
11-30-2006 16:57:39
 Re: Ambac PSB 6 Injector pump in reply to Scupper, 11-29-2006 16:53:18
I sent you an e-mail. Did you check the valve recession in the cylinder heads while you were doing the rebuild? Let me know if you do or do not get the e-mail. J.
