VAC return spring linkage
Steve_Md
11-29-2006 05:45:27
I have a 1947 Case VAC that I am restoring and I have the hydraulic ram return spring but am missing some of the linkage. It appears their is an oval steel loop on the ram end of the spring that hooks over the ram linkage and a bracket on the differential/brake housing side of the spring. I need the material sizes and dimensions of the steel loop and the differential bracket. Is their anyone that has this setup and is willing to make the measurements? A picture would really help also. Thanks in advance!
mj
11-30-2006 19:11:44
 Re: VAC return spring linkage in reply to Steve_Md, 11-29-2006 05:45:27
third party image
Looks like the 'old dog' beat me to it..... 'atta girl, boy!'. Anyway, what I came up with is the 'C' link is out of 3/8" stock; 3" long and 1 1/2" wide. If you look at the photo you'll see that on this tractor the 'C' is actually a ring flattened to an oval. You will also see a black nylon tie around the clutch rod and passing thru the oval link. This is to prevent losing the link in the field when, not if, the spring breaks. I've welded up both ends of this spring over the years. As for the tab that holds the other end of the spring I measured it as 3/8 x 1 1/2 x 2 3/8 long. one hole is a loose clearance diameter for the spring and the other is a clearance size for the housing cap screw. I've posted more photos (38 thru 41) for you on my website; just click the link and click an image to enlarge.
olddog
11-30-2006 06:56:23
third party image
The "C" shaped oval ring is 1/2 stock about 2" in the "wide" part of the oval, open one side. The bracket on the brake cover is 3/8 or 1/2 stock with small hole and big hole about 1 1/2 or 2" on center. A pict of the bracket is in parts&pieces on the lh side under galleries.
varmint
11-30-2006 13:02:54
 Re: VAC return spring linkage in reply to olddog, 11-30-2006 06:56:23
third party image
check the link for th parts list from the index which is the 1st photo but the one you want is page 113
mj
11-29-2006 18:53:18
third party image
Yeah, I thought I had a photo on my page BUT for some reason the spring and link weren't on there when I took the pic SO i will take another tomorrow and also take some measurements and post them here sometime in the evening.
