Hydraulics on 1175 -
Wojfarm
11-27-2006 16:13:00
I recently purchased a 1175 and discovered that the dual remote hydraulics do not respond when trying to activate with the controls. The 3-point hitch comes up slowly when it is activated. Any recommendations as to were to start trouble shooting? Could there be something I'm overlooking? Any recommemdations would be appreciated. Thanks
Grumpy
11-28-2006 05:11:31
 Re: Hydraulics on 1175 - in reply to Wojfarm, 11-27-2006 16:13:00
Is this your first Case tractor. If it is then you need to make sure you have hoses hooked up right. The top left and the top right are a pair and the bottom ones are a pair. Go to your local farm supply store and get a 3000 psi gage and a hyd. tip to fit your tractor and whatever fittings to hook the two together. Put this gage in each coupler and check pressure. Do this and check back and we can go from there. Stan
dwag
11-27-2006 16:53:38
These are the steps I use. 1, check press at remote outlet(should be around 2000#) 2, flowcheck pump(2000# at 16 GPM) 3, and most common, remove seat, seat platform, and remote valve to repair relief valve(usually a blown o-ring, "A17526) The nastiest part of job is step 3.
wojfarm
11-27-2006 17:55:16
 Re: Hydraulics on 1175 - in reply to dwag, 11-27-2006 16:53:38
Where would I get the type of pressure and flow guage you suggest? Also, without checking, do you think it will be necessary to take off the cab to get to the relief valve? What is the probability that it is a blown o-ring? Thanks for your help!
wojfarm
11-28-2006 17:35:38
 Re: Hydraulics on 1175 - in reply to wojfarm, 11-27-2006 17:55:16
As you suspected it is my first Case and I had the hoses incorrectly attached. As soon as I went from top to top, and bottom to bottom, the cylinders worked perfectly. Sure makes a guy feel dumb.....
I sure am greatful for your reply and this site. Saved me lots of grief, time, and money. Thank you again!
dwag
11-28-2006 10:39:42
9 times out of ten the problem is relief valve. Cab dosn"t have to come off. Seat and rectanguler riser\platform need to be removed to remove top 2 mounting bolts of remote valve. Given the age of these tractors, it"s important to check pump. It would be worth your money to have a shop flow check for you. (flowmeter $450)
