Case SC Value
Jim Wooley
11-25-2006 17:32:35
I am considering purchasing a 1953 Case SC that is complete minus the starter. It has the cultivators and planters that were used for black eyed peas. It has been sitting for two years and the owner does not know if it will turn over or not. the tires are all flat and in bad shape. It does have the rear lifting hitch on it.
Can anyone give me a ballpark price for a tractor in this condition?
thanks...Jim
C. Amick
11-27-2006 17:20:21
 Re: Case SC Value in reply to Jim Wooley, 11-25-2006 17:32:35
Check the serial number. If it has the lifting bail and not the 3pt. Eagle Hitch, it is not a 1953 model. A foot clutch makes it more valuable, but they are more prone to sticking. I'm thinking around $800 with the cultivators, if the engine is stuck. You may have to loosen the brake drums to get it to move. They may be stuck as well.
Jim Wooley
11-27-2006 18:15:55
 Re: Case SC Value in reply to C. Amick, 11-27-2006 17:20:21
I am new to the Case line and really appreciate the help.
Jim
Glenn FitzGerald
11-26-2006 06:15:28
It sounds like there will be no trucking cost...? I paid $1000 for my '54 two years ago. Included in the deal was a Case-Danuser blade and new tire chains. My rear tires are very poor, fenders were shot (I did extensive repair on them), and the ring gear needed replaced. It also needed a set of rings as it burned a great deal of oil. The cylinders and crankshaft mic'ed out near perfect. I feel I got a good deal on my tractor. If "yours" has foot clutch, eagle hitch, live pto, and compression, I think $1000 is a fair price. If you really want it I'd even go up to $1200. A starter will be easy to get. They sure are nice little tractors. In addition to numerous miscellaneous repairs, I have put an adjustable front end on my tractor. I have been around CASE tractors all my life and had never seen an SC with awf. It sure gives it a different look and is also very nice to operate.
Good luck, Glenn FitzGerald
Jim Wooley
11-26-2006 15:07:46
 Re: Case SC Value in reply to Glenn FitzGerald, 11-26-2006 06:15:28
Glenn,
Thanks for the help. I have been around John Deere all my life and had six of them restored and an Oliver, but had to sell them all when i got a heart infection. Doing well now and want to have some old iron to tinker with but don't want to go the JD route. There are quite a few old Case tractors in our area. I guess at one time there was a very good dealer in the area.
The tin in really good on the tractor. The front tires are ok, but the back ones will need to be replaced. I have found a used starter already for $75. Are the mags expensive to have rebuilt. The current owner bought the tractor from the farmer who had originally bought it. The way he described it quitting and not being able to restart it sounds like the mag may have lost it's fire.
I saw a wide front SC advertised on Yesterday tractors but no picture. I would like to do the same thing. Do you think you could send me a picture of yours. Also where would i look for a wide front?
thanks....Jim
Camboted
11-25-2006 20:28:12
If it is a 53 it has Eagle hitch and live PTO, may have foot clutch. IF IT DOES NOT HAVE THESE IT IS PROBABLY NOT A 53. All of these add value along with the planter and cultivator. My guess is $700-1100 depending on the sheet metal, fenders, lights, etc.
Jim Wooley
11-26-2006 05:16:36
 Re: Case SC Value in reply to Camboted, 11-25-2006 20:28:12
Thanks for your help. It does have the foot clutch. The sheet metal is excellent, but the lights are missing.
Jim
