5 furrow Case plough
Mitch Furness
11-23-2006 13:21:17
Link
Link
Hi Everyone
Can onyone tell me if a David Brown 1210 would be able to manage this 5 furrow Case plough. Does anyone have a similar machine. It is reversable (hydraulic). My 1210 is fully balasted front and back with tubes filled with water in rear tyres as well.
Regards
Mitch
Gator04
11-30-2006 09:59:49
 Re: 5 furrow Case plough in reply to Mitch Furness, 11-23-2006 13:21:17
I did see the pictures - I have never seen a "Disc" Plow before - would be interesting to see one work.
Mitch Furness
12-01-2006 02:19:03
 Re: 5 furrow Case plough in reply to Gator04, 11-30-2006 09:59:49
Gator do you have any pictures of your 1210? They are not too common here.
Mitch
Mitch Furness
12-01-2006 02:16:33
third party image
Gator this a Massey Ferguson 3 furrow version. These ploughs are very common here in Australia, they are especially used in sandy type soils or soils with lots of sticks and or rocks as they are not damaged when they strike submerged objects. They do an excellent job of turning over the soil, can leave the surface rough though. Primary tillage machines.
Cheers
Mitch
Gator04
11-28-2006 09:56:20
I as well pull a 4 bottom 16 with my 1210, in the real heavy clay at times I have to throw in the front assist on it though.
amo
11-23-2006 16:36:47
I PULLED A FORD 4 BOTTOM 16 INCH PLOW WITH A CASE 1210. THE TRACTOR HAD SELECTA-SHIFT AND DID A GOOD JOB.
Mitch Furness
11-28-2006 11:47:33
 Re: 5 furrow Case plough in reply to amo, 11-23-2006 16:36:47
Thanks guys mine is a 2 wheeler. It sounds like 4 furrows is enough. Not sure if you saw the pics, this plough is a 5 furrow disc job.
Mitch
