increase power of 1394
ballylemon
01-16-2006 06:41:29
i would like to find out about how to increase the horse power of a caseIH 1394 and if i increase it will i run into problems the cooling system, the clutch, the PTO or with the hydrashift gearbox. i am also looking to put those PAVT back rims with the weight built into them no it and i was told that a massey rim will fit a case - is this correct
Paul in Wi
01-16-2006 07:22:38
 Re: increase power of 1394 in reply to ballylemon, 01-16-2006 06:41:29
We have 1494 and a 1394 were I work, the biggest thing I was able to power was the 15 ft brush hog and the temp gauge started to climb on me if I pushed it hard.(this was with the better running 1394,which seems stronger,and has less hours,but was rated 10 less hp.) I don't think thier enough tractor to be able to put much extra power to the ground. handy cheap tractor though,with that David brown turbo 4 cylinder they get good fuel economy for a 60-70 hp tractor. Did not know they came with any kind of a power shift, is it a 3 speed like in a 2090?
ballylemon
01-16-2006 12:36:16
 Re: increase power of 1394 in reply to Paul in Wi, 01-16-2006 07:22:38
its a 4 speed powershift i don"t know if it works on a similar basis to the 2090
