Jheitkemper
11-23-2006 09:25:58
Re: Case SC leaking transmission fluid out of brak in reply to hayrookie, 11-23-2006 00:45:23
Keep the oil level up where it should be .Around this farm I pride myself in farming and working with tractors My Uncles and Grandpa sworeby ..I have a nice 54 SC that came wandering in here looking for a home after years of Neglect ,,Tranny was low on fluid ,Leaking out the brake seals, ,and made a slight noise that was out of character of other SC,.. Turned out the front bearing on the PTO shaft was shot ,NO OIL can get up there when the level is not maintained ,,.., We put LUCAS HUB SEAL in the tranny ,and run it for a week and that is all I did to hold the seals ,That was 8 years back , and it is fine today ,,The PTO bearing finally gave out last fall and demanded to be fixed ,that One is a Tuffy to fix .. And The Brake seals are a Problem to change out from MY experience Too ..But To Be Honest ,,I DO not like to Pull Wrenches ,I prefer the Steering Wheel .and will try the Mechanic in a Bottle before I take one apart . I have no ties with LUCAS OILS ,BUt I wish I did ,,It Really is GOOD STUFF , NAPA should have it .. GOOD Luck ,and Happy THanksgiving , Jim
