Case Model 311
Hoffman
11-22-2006 16:23:01
Just acquired a Case 311 that has sat for 10-15 years. Engine started but hear knocking noise. How do I drop the pan to investigate further? Thanks
C. Amick
11-23-2006 11:58:26
 Re: Case Model 311 in reply to Hoffman, 11-22-2006 16:23:01
I bought one that may have had the same problem. I only had about 10 psi of oil pressure. The No. 2 rod bearing was shot. Also the oil filter housing stem was missing and thus not allowing oil to be pumped up into the head. I also had some bent push rods. Pull the oil filter off and see if there is a hollow metal stem present that the filter slides down on.
Hoffman
11-23-2006 04:26:42
Thanks. Have ordered manuals.
Camboted
11-23-2006 02:24:05
Well, if you are adventurous, grab a wrench and start loosening bolts, I don't think you'll get into too much trouble. However, if you are the cautious type, I'd suggest you buy an IT manual on this site, or watch for one on ebay. LOL!
