Case Eagle Attachment
Paul in On
11-21-2006 15:33:56
Odd question, but how have some of you attached the eagles to the front. Mine just has pegs with no clips or anything. DOn't want to drill into it and don't glue didn't work. Thanks. Paul
Joe (Wa)
11-21-2006 19:15:12
 Re: Case Eagle Attachment in reply to Paul in On, 11-21-2006 15:33:56
What you need is push-on retaining clips, grips on the peg the same way that push-on nuts work on toys that have same to secure a wheel to the axle. Some hardware stores carry an assortment.
I don't know your peg size but for 300, 300B and 400B front emblem the retaining clip is Case p/n A11319, probably obsolete?
Joe
Lamont
11-21-2006 19:02:45
I used a die and threaded the posts on mine and secured it with nuts. Don't remember what size but it has worked for 3 years and is still tight. I know the posts are not round but the die will thread it enough to hold. The metal is really soft so be careful not to over tighten. I used self locking nuts. Completely eliminated the clips.
Old Magnet
11-21-2006 16:25:07
Just installed one on my 530CK. I used a couple of 1/4 in. stainless steel shaft collars with the set screw on the flats of the mounting posts.
