case M570AT
Curt Gregory
11-21-2006 05:54:24
I have 1970 m570at with w3 model 42 loader&hoe installed,was military,g159b with COM,4speed, no dual range or shuttle,does not have much power in torque converter drive,better after warmed up,direct drive ok,pressure on gauge wiyh clutch out is just bareley in green zone, is there some way to adjust pressure regulator?? seen some old posts that describe using additional washers for spring tension,any advice would be greatly appreciated, also could a dual range or shuttle be installed and what would fit? 530? thanks Curt Gregory
