sc head gasket problem
Frank in Sask
11-20-2006 16:27:18
Overhauled my SC a while back. Noticed there was some antifreeze seeping abit from the head gasket right above the mag. So decided to retorque the head. Not long after I noticed anti freeze in the oil. Decided to change head gasket. The new gasket is the same as old, metal on both sides. Do they not make a fibre gasket for the S series. If I have to use the metal gasket what should be used to get a better seal. Some say to coat with grease or is there a good sealer . Used coppper spray last time.
C. Amick
11-21-2006 09:25:21
 Re: sc head gasket problem in reply to Frank in Sask, 11-20-2006 16:27:18
I have used the "block sealer" to stop sleeve "O" ring seals leaks. It works with water, so you will have to remove the coolant until the sealing proceedures are complete. I did it in the Winter and had to block air flow through the radiator to get the engine up to the required temperature.
c hess
11-20-2006 16:39:42
Dont use anything on gaskets as they have there own sealer on them.Suppose you could also have warped head or block surfaces. I would just put Bars leak or other sealer in radiator . I think that would seal up head an stop leak getting in oil . If you check closely afterward you will be able to tell if it works.Have used stuff many times.Having pulled head you may have caused cylinder o rings to seep but sealer will correct that.
