1958 500 Engine question
INCase
11-20-2006 09:58:48
I looked at a "58 500 (511) a week ago. I noticed it had an acess plate on the left side of the engine. I got to thinking about it the other day and realized I didn"t see that plate on other 300"s and 400"s I"ve seen. Did the 500"s have that plate? and/or what is the difference in that engine versus the 300/400? Its not "bad" looking and he wants 1400 for it but the plate makes me wonder. Thanks.
rongrong
11-20-2006 18:58:34
 Re: 1958 500 Engine question in reply to INCase, 11-20-2006 09:58:48
the plate you are looking at is a cover over the cylinders/water jacket to clean out between them. check to see if this leaking,or rusted out.. also this not an engine like a car engine without sleeves, it has sleeves,i know because i bought one for about $90.00 from case . this engine was a dry sleeve engine.. another thing to check on that plate, if the generator is mounted on it,look for cracking or breaking where the bracket is welded on ..this plate was not available from case,so i had to weld mine ,then i found that is was also bent two gaskets and lots of gasket silicone solved it...
Martin in DE
11-20-2006 14:45:06
INCase,the engine you are looking at is a 164CID dry sleeve engine. The 300/300B/400B used the 148CID engine but the block is not the same in the 300/300B as the 400B. BTW a wet sleeve replacement engine was made after 1960 for the 350/500B/600B tractors. Martin
INCase
11-20-2006 12:20:08
I forgot to mention this is a gas tractor. Thanks.
BarryfromIA
11-20-2006 11:08:43
The 350, 500, and the 600 had a no sleeve block. Or automotive type block. This was not well received by some in the farming business, because most tractors last many years requireing several overhauls. Apparently the 188 cu in engine was not yet ready for use, or perhaps not thought of yet.
