Diesel misses under load or acceleration
Keith
11-26-1999 16:32:25
Hey Guys!
Here's another diesel question: The excavator started and ran well on Wednesday and today started as usual but misses at any rpm above idle. What I see as the engine accelerates is puffs of grey smoke timed with a noticable engine miss. We changed the filters and drained some of the diesel looking for water. We suspect that the fuel is loaded with water but haven't been able to confirm this with actual observation. Any ideas? This is a 6 cylinder diesel with compression release, and a japanese motor in a 50000 lb excavator. You case guys know more than most and I need some fast help!!
Thanks,
Keith
Larry
11-26-1999 17:13:02
 Re: Diesel misses under load or acceleration in reply to Keith, 11-26-1999 16:32:25
A diesel is a diesel. Try bleading the feul lines at the injectors. Sounds like you have air in the system some place.
Chris Vangel
11-27-1999 08:43:00
 Re: Re: Diesel misses under load or acceleration in reply to Larry, 11-26-1999 17:13:02
It could be air in the system, but I think it would have to be trapped at one injector if it is always a single cylinder miss with the smoke as described. I think it would be strange for only one injector to be airlocked all of a sudden. if possible a compression test might be in order. You might also listen to the injectors with a stethscope to see if they are working. should be a sharp click heard at each one. If one is different that would be the culprit. With the smoke in time with the miss, I think it is one particular cylinder. It is possible an injector is clogged or dirty also. Either lean fuel or lack of compression is most likely problem,I would think. Not a Diesel pro, but it's where I would start if your sure you didn't run it out of fuel. Good luck, Chris.
Wayne
11-27-1999 18:52:53
 Re: Re: Re: Diesel misses under load or acceleration in reply to Chris Vangel, 11-27-1999 08:43:00
Sounds like you have a bad injector here. Especially if it just started without breaking the fuel system open. Also if that cyclinder if firing at idle and not at rpm above idle then I wouldn't suspect compression. The faster the engine runs the better it will fire on less compression. One other thing could be a valve sticking at the higher rpm. I would suspect a bad injector or injector pump on one cyclinder only or possibly a sticking valve. Hope this helps...
