Wanted Case L
Josh Wilhelm
11-16-2006 18:19:06
I would like to find a Case L thats new enough to have a starter I think 38 and newer. I would like it to be close to MN. Tractor doesn"t need to be complete or run just mostly there. I know this isn"t the classifieds but I havent had much luck there yet. Thank you
Joe Peeper
11-17-2006 11:02:33
 Re: Wanted Case L in reply to Josh Wilhelm, 11-16-2006 18:19:06
Let me know when you are ready to buy an L with a starter. I have several to choose from. Thanks, Joe
DurangoCase
11-17-2006 07:37:43
I've seen pulling L's with starters mounted out front where the hand crank used to be. just a thought.
Chances R
11-17-2006 04:24:56
third party image
Here is a nice tractor owned by Dave Olson. I dont think it is for sale though
Dave Olson
11-17-2006 17:32:39
 Re: Wanted Case L in reply to Chances R, 11-17-2006 04:24:56
third party image
The old L been givin us a hard time, still not for sale though! :-)
Took it to a local show this year and all was fine until loading it up for the trip home, engine died half way up the ramp!
Earl from Mohomet said he would try to get over one of these days and check out the mag that we had rebuilt.
We pulled the frontend off to inspect the govenor assembly. Replaced the thrust bearing. Everything else looked Ok.
Dave Olson - East-Central Illinois
Dave Olson
11-17-2006 17:45:18
 Re: Wanted Case L in reply to Dave Olson, 11-17-2006 17:32:39
third party image
Just wanted to share another picture with you folks.
I hope to attend the National Case Show that will be held at my local tractor club in 2008. My plan is to have the L on the trailer and will put the little C on the deck of the truck.
Antique truck ('46 White) haulin an antique tractor ('30 Case C), pullin an antique trailer ('70 DoMor triaxle), haulin another antique tractor ('38 Case L). :-)
Old Tractors n Old Trucks are fun!
Dave Olson
Ps: Might start thinkin about selling after that show, Naw!
Ande
11-20-2006 05:29:20
 Re: Wanted Case L in reply to Dave Olson, 11-17-2006 17:45:18
Dave,that is one good lookin rig,must be just great driven that old girl,(truck)do you know the history of her? Over the road truck I suppose.
Ande
Dave Olson
11-20-2006 06:42:14
 Re: Wanted Case L in reply to Ande, 11-20-2006 05:29:20
third party image
Hello Ande,
This old truck, 1946 White WB-22, came from Pennsylvania. Fellow I bought it from said that he got it from the original owner. I was told that it hauled steel in its previous life.
We have done quite a bit of work to the truck in the short time that I�ve had it. Earlier this year we completed a complete engine overhaul. The engine is a 386 cubic inch 6 cylinder flathead that is rated at 138 horsepower. It has a 5-speed transmission. Forth gear is direct and 5th is overdrive. It has air brakes and a 12-volt electrical system. The body needed a lot of attention too.
For the past few years I�ve been acquiring things from my past, this old truck is similar to the one that we had when I was a kid on the farm.
All of my tractors are examples of equipment that we had on the farm in the mid fifties. Here is a picture of the Old White while I was driving it in the Half Century of Progress Show, Tractor Ride in August 2005. The Farmall H on the bed of the White is what started this collecting process in 2002.
Dave Olson � East-Central Illinois
Ande
11-21-2006 05:27:11
 Re: Wanted Case L in reply to Dave Olson, 11-20-2006 06:42:14
Dave, thanks for sharing those great pictures and history of the truck.Gee I just love reading about bringing these old pieces back to life.And then putting them back into what they were intended to do
Thanks again
Ande
Ande
11-16-2006 18:52:15
Josh,I have a "38" "L" and it does not have a starter,maybe the "pros" in here can correct me,but I dont think the "L" came with a starter.I'm close to you over here in ND I have a older "L" think it is a early "30's"
Ande
rusty tractors
11-16-2006 19:23:25
 Re: Wanted Case L in reply to Ande, 11-16-2006 18:52:15
I think ande is right. I have never seen an original L with a starter. There were a few out there that someone had installed a LA engine in and they had starters. I also have a late 30's L and it doesn't have a starter. I hope I am right but I can be corrcted.
Brian in Ohio
11-16-2006 19:20:11
The later Model Ls could could be ordered with an electric starter.
However, out of curiosity, why not build up an LA as a pulling tractor? There are a few more of those around, they are already set up with an electric starter, and you can build one with a 3-71 Detroit, ala Don Livingston.
There's a stout booger...
Tom Railsback
11-16-2006 21:40:41
 Re: Wanted Case L in reply to Brian in Ohio, 11-16-2006 19:20:11
The electric starter became standard at 4206422. However, the LI's had starters back as far as 1929.
