unstyled R C
Dale Edmondson
11-15-2006 11:21:30
I have an unstyled 1935 R C that has a 4 speed transmission. Can this be the way it came out
or was it probably added at a latter date.
It also has a starter. Any ideas Thanks
fshook
11-19-2006 22:41:12
 Re: unstyled R C in reply to Dale Edmondson, 11-15-2006 11:21:30
there is no doubt In my mind that all RCs with exception to the first run in 35 that they had 4 speeds they may have the gear blocked on the shift rail I understand that Case blocked all 4 speeds out on tractors that left the factory on steel for obvious reasons the dealer should have unblocked them when they converted them to rubber but many did not do this also I have never seen one with the 4 on the trans top. I once owned the overhead steered RC on casemans rc page it had 4 gears, I drove it in 4th to the shipping dock when it went to MO.last summer take a look around casemans site it is of the very best on case tractors
dboll
11-18-2006 07:02:20
my 36 RC also has a road gear (4th)
Brian in Ohio
11-15-2006 14:39:25
Is the fourth gear marked on the transmission cover? A lot of the early RCs came with a "hidden" fourth gear.
