Case 970 q's
new farmer
11-14-2006 16:45:47
i Have Case 970 Diesel Powershift. My first question is, did they come with a factory turbo or was that an add-on? Mine has onw but it looks after-market. Second question, How much Hydralic oil do these hold? Mine is getting a little low and needs to be filled up. Final Question, Do those 970s have both 540 r.p.m. and 1000r.p.m. pto? thanks everyone
Joe-Bob/IN
11-15-2006 15:36:46
 Re: Case 970 q's in reply to new farmer, 11-14-2006 16:45:47
Should be two sight glass bulbs on the left side of the rearend housing under the platform behind the steps but in front of the axle... or somewhere near there. I'd be careful with that turbo on there, Cases were pretty stout but you may start to slip the clutches which could be fixed by adding 1070 internals with extra clutches.
Eagle Doc
11-14-2006 23:12:43
970's were not turbo'd from the factory.
The transmission/rear end/hydraulic reservoir holds about 17 gallons of oil.
Dual speed PTO (540 & 1000) was actually an option on them but I have never seen a 970 that didn't have dual speed.
