Case 430 that was on Ebay
Kevin5456
11-14-2006 16:06:56
There was a tractor on ebay, Item number: 330047491809. $2750 is too much for it. I was wondering what I should offer him. I E-mailed him and found out that he is putting the older tires back on.
wide axle
11-15-2006 15:55:04
 Re: Case 430 that was on Ebay in reply to Kevin5456, 11-14-2006 16:06:56
The 430 was the best tractor ever made. Have had numerous others(like 15-20) and still would rather ride the 430 my dad bought new in '69 than any other tractor that I have seen including cab tractors. Anybody that doesn't like one must bleed green.
sunny 4 acres
11-15-2006 14:23:11
i have a 430 case. Too light weighted but one of the best brushhogging tractors I have owned. The pto can be live or independent with either one of the clutch choices. Souns like Ken L better learn the 430
Ken L.
11-16-2006 16:44:44
 Re: Case 430 that was on Ebay in reply to sunny 4 acres, 11-15-2006 14:23:11
As I said, junk. Maybe yours was better
Kevin5456
11-14-2006 19:42:02
dctom,
what is a com?
hammerstrap
11-14-2006 20:21:37
 Re: Case 430 that was on Ebay in reply to Kevin5456, 11-14-2006 19:42:02
Case-o-matic is a underdrive somewhat like multi power or torque amplifier. Only the case version has hydraulic activated clutch pack which was J U M P Y. Often nick named; slam-o-matic, jerk-o-matic, leap-o-matic, or s#!t.
dctom
11-15-2006 06:06:09
 Re: Case 430 that was on Ebay in reply to hammerstrap, 11-14-2006 20:21:37
your supposed to read the instruction manual and learn how to run a automatic transmission, com was the best trans ever put in a tractor names like youjust posted were guys that didnt know how to run them
Kevin5456
11-14-2006 19:30:17
Ken,
You must of had a bad experience. I have one now, works great. but I think I will let it pass.
dctom
11-14-2006 17:20:31
seems awfull high to me, not even sure it is a 430, looks more like a 300 , most all 430 had com
dctom
11-14-2006 17:19:43
seems awfull high to me, not even sure it is a 403, looks more like a 300 , most all 430 had com
Ken L.
11-14-2006 16:27:12
If it's anything like the 430 that we had, I would leave it where it is. Bought it new in 68. Worst tractor I've ever seen. Underpowered, power steering was so slow that if you wanted to make a short turn, you had to stop, steer, go around the corner, stop, steer straight and then go. Independent PTO needed constant repair, clutch was so jerky that nobody would hold a wagon pole while you were backing up to it for fear that they would get run over. Had six other tractors at the time and all were older. All six together didn't cause half the problems that the 430 did. That tractor made us happy once and really happy once. Happy the day we bought it and really happy the day we got rid of it.
kyel
11-15-2006 14:09:39
 Re: Case 430 that was on Ebay in reply to Ken L., 11-14-2006 16:27:12
you most ofnot known what you where doing, or maybe you should be on the john deere forum
Ken L.
11-16-2006 16:47:05
 Re: Case 430 that was on Ebay in reply to kyel, 11-15-2006 14:09:39
Drove Cases for years and loved them but wouldn't give a nickel for a 430
