David Brown runs out of fuel
Ken Schmidt
11-13-2006 18:52:41
I have a D B 990 I purchased not long ago. It runs out of fuel w/ 1/2 tank of fuel left in tank. Fuel is just below what looks like a baffel plate in tank. Is fuel inlet just a piece of copper line going down to bottom of tank? I suspect if so must be hole in tube, or it broke off. Anyone had such experience?
Geoff wolfenden
11-15-2006 13:34:59
 Re: David Brown runs out of fuel in reply to Ken Schmidt, 11-13-2006 18:52:41
I have had david browns stop on me and they have had some straw or dirt in the pipe in the tank to test try blowing back into the tank and see if there is a blockage
Ken Schmidt
11-14-2006 11:12:24
The tractor starts up after putting fuel in and bleeding the lines. It's done this to me about 3 times already.
richard in nz
11-14-2006 02:48:39
It is quite common for the fuel lift pump push rod to wear away reducing the length of stoke of the lift pump on David Brown engines, it will give exatly the symptoms you describe. Check for a blockage in the system or a faulty lift pump and if you cant find a problem you can be fairly shure it is the push rod.
