440 case pto
hammerstrap
11-13-2006 17:31:54
Is it possible to put a pto in a bareback tractor?
Beautiful little tractor no 3 point or pto.
Bareback Blues
11-13-2006 20:39:38
 Re: 440 case pto in reply to hammerstrap, 11-13-2006 17:31:54
No expert, but I think you can add a standard pto, but not the independent pto without changing the crankshaft in the motor.
3 point hitch requires changing out your cast cover under your seat that houses the internal cylinder. I don't know what all gets changed inside, but quite a few hydraulic lines and valves and linkages to add the draft-o-matic.
Eagle Hitch would be easier but not as nice.
Some guys have homemade 3 point hitches and use their remote couplers to lift it up and down with an external cylinder like the old 400 Case.
