Case LA Radiator
Theodores
11-13-2006 12:28:38
I have a 51 Case LA that I recently purchased. It runs great, but when plowing with it this past weekend, steam came out of the radiator cap at a very quick pace. I realize the machine is getting hot, but what can be done to resolve this? The fan is turning, air is being pulled through the radiator. It has water/antifreeze. Does it contain a thermostat? Are the insides of the radiator clogged? Could it be a cracked head? Since it appears to be Case LA day here, maybe I can find an expert. Thanks for the help in advance!
Richard G.
11-14-2006 17:00:15
 Re: Case LA Radiator in reply to Theodores, 11-13-2006 12:28:38
One LA I worked on had a thermostat in the neck between the radiator and the head. Just unbolt and take a look. Also check to make sure your fanbelt is tight.
shovelbuzzard
11-14-2006 14:59:11
hey zach, case tractors are great,but a 1951 model still under warranty! WOW i wonder if my 41vc is covered too!
Walt Davies
11-14-2006 16:53:52
 Re: Case LA Radiator in reply to shovelbuzzard, 11-14-2006 14:59:11
I have a lifetime warrantee on my 69 Saab Sonett.
The company is telling me I need more proof brfore they will ohner it. I told them its pretty bad when a guy out lives his lifetime warrantee.
Walt
ZACH2322
11-14-2006 13:18:19
IM NOT SURE WHAT PROBLEM YOU HAVE THERE. IT IS ALWAYS IN MY EXPERIENCE TO CALL THE MANUFACTURER AND FIND OUT IF THERE IS ANY WARRANTY AVAILABLE ON YOUR UNIT. IT SOUNDS LIKE TO ME IF WARRANTY IS NOT AVAILABLE THEN YOU MAY WANT TO SWING THE ENGINE WITH A REBUILT ONE FROM AUTOZONE. THEY HAVE VERY NICE REBUILT JASPER ENGINES THERE. IF YOU HAVE ANY MORE QUESTIONS JUST LET ME KNOW. THANKS.
Walt Davies
11-13-2006 14:42:00
Funny my parts book also shows the thermostat but the drawings show no place for it to go. I have a 45 and 48 and niether have a thermostat they use the radiator shutters. I wonder if the book could be wrong.
If it was tractor and knowing what I know about the LA's I would take the head off and raditor off and and clean and check the whole system before you do any real damage to the engine.
There are many problems with the cooling system on the LA that will only show up under heavy working. Walt
Gene Dotson
11-13-2006 14:02:55
The LA doesn't have a thermostat. Heat is maintained by shutters. It may have shutters closed. Check this before you do anything else... Gene
Tom Railsback
11-13-2006 14:21:01
 Re: Case LA Radiator in reply to Gene Dotson, 11-13-2006 14:02:55
Genbe: My parts book shows a thermostat; part number is o8989AB.
Tom Railsback
11-13-2006 12:40:05
IT could be a thermostat, but my guess is a plugged core. Drain it, fill it with vinegar, yes, plain old vinegar, warm it up, let it set a day, drain it, and then back flush it through the drain pipe.
It's possible that the engine block is full of rust, in which case you are looking at a major and expensive teardown as gaskets now run over $300.00 a set.
It could also be a bad water pump and I don't know of a source for parts or rebuilt ones for the LA.
AllanC
11-13-2006 21:32:17
 Re: Case LA Radiator in reply to Tom Railsback, 11-13-2006 12:40:05
I expect the radiator core is plugged up. Rust flakes etc do this. If the vinegar treatment suggested doesn't work, take the radiator apart and clean it - or have a rad shop do it if you are not comfortable tackling it. I've had to do this a few times in my farming life with L and LA tractors.
Tom Railsback
11-14-2006 06:18:26
 Re: Case LA Radiator in reply to AllanC, 11-13-2006 21:32:17
I would try to disassemble and reassemble it myself if possible as our local radiator shop charged me $300.00 to do it. Once it's apart they shouldn't charge that much just to boil it out.
