L/LA CASE TRANSMISSION=500 DIESEL TRANS
TRACTORNUTJD
11-13-2006 10:32:05
COULD SOMEONE HELP WITH A QUESTION. mY FRIEND AND I DIFFER IF A L/LA USED THE SAME TRANSMISSION PARTS AS A 500 DIESEL THANKS
1200TK
11-13-2006 11:59:23
 Re: L/LA CASE TRANSMISSION=500 DIESEL TRANS in reply to TRACTORNUTJD, 11-13-2006 10:32:05
Hi tractornutJD,
You ask wether the transmission, used in the CASE models "L", "LA" and "500" Diesel tractors are the same, the answer is 99.9% of parts are exactly the same and interchangeable model to model. However the model "L" was only a three speed machine, with the exception of the very late model "LAI" industrial tractor which had a four speed transmission.
In actual fact most of the "LA" parts are the same as those used in the models "600", "900" and model "930" tractors with complete sucess and durability, even with all that extra horse power. That alone proves just how well designed that CASE transmission is. The only major difference with the "L" "LA" "500" and "600" AND THE LATER "930" is that the final drive chains are heavier, being 2" pitch for the "930" while the others including the model "L" were 1 1/2 pitch chain.
Hope that this settles the difference of opinion with you friend, concerning what in it's tme was the BEST wheel tractor transmission in the WORLD !!
Regards.
Alan.T.Lewis
Christchurch
NEW ZEALAND
tractornutjd
11-14-2006 09:08:00
 Re: L/LA CASE TRANSMISSION=500 DIESEL TRANS in reply to 1200TK, 11-13-2006 11:59:23
So are you telling me a reverse idler and shaft out of a la will fit in a 500 diesel? That would be totaly awesome thanks, tractornut
Tom Railsback
11-14-2006 14:18:16
 Re: L/LA CASE TRANSMISSION=500 DIESEL TRANS in reply to tractornutjd, 11-14-2006 09:08:00
The part numbers are the same so I see no problem.
Tom Railsback
11-13-2006 12:33:28
Alan: I know from experience that the bull gear and pinion was changed at least twice in the LA's. I broke a drive chain in 1972 and failed to get a small piece of it out. About 6 months later my dad started the tractor intending to do a bit of grading with a pull type grader. The transmission locked up on him and when we got into it, we found that part of one of the bull gear teeth and a couple of pinion teeth were gone. The parts book shows 3 different combinations. We could find lots of early pinions and gears and a few pinions for later ones, but we never found the correct bull gear for a tractor with disc brakes. We finally got a gear from the second series and had the ring pressed off its hub and onto our hub. The reason for the last change was to accomodate the disc brakes on the differential shaft.
thehickdaddy
11-14-2006 14:20:07
 Re: L/LA CASE TRANSMISSION=500 DIESEL TRANS in reply to Tom Railsback, 11-13-2006 12:33:28
my dad put the guts of two LAI's into L's and now we have 4 speed, quiet L's with rubber steering wheels. anybody else do that? also, 500 have bigger final drive chains.
