Case 2470 aspirator pipe
Mike S 806/H
11-11-2006 16:48:19
I built a new exhaust pipe from the turbo to the outside of the hood, im using a straight pipe on it and need to weld the aspirator pipe in yet, I would like to weld it in under the hood so you dont see it out side, will this be ok? I want to keep a cleaner look,
Jim B.
11-11-2006 17:06:39
 Re: Case 2470 aspirator pipe in reply to Mike S 806/H, 11-11-2006 16:48:19
I also have a 2470 and when the muffler blew-out some years ago it lost alot of power. It wasn't too noisy but needed to drop a gear to chisel plow... yes I was surprised too. Dealer said the exhaust system designed-in back pressure was required to produce full turbo boost. Your effort to make it pretty may deter from field use. Also, won't you now need to remove the straight pipe to remove the hood. I'd suggest you not mount the new pipe directly to the Turbo outlet it's not designed to carry the weight of anything.
Mike S 806/H
11-11-2006 19:08:09
 Re: Case 2470 aspirator pipe in reply to Jim B., 11-11-2006 17:06:39
I built the new pipe just like the original pipe dealer wanted about $450.00 for It, I have about $70.00 in it, I could mount a new muffler but want to keep the straight pipe
