VAC pto Cover, crank, etc.
GlennFitzGerald
11-11-2006 16:44:21
I'm like a kid waiting for Christmas. I have bought a VAC 14 over in Michigan which I'll be going to get in April. A few things it needs is a pto cover and a starting crank. Also the picture shows the drawbar cut off. Apparently this was done to make more clearance for the mounted scraper blade. Are these items the same for all VAC's, or just the 14? Dad had a VAC but he traded it off on our '51 DC seven years before I was born. It also needs a temp guage, but of course I'll get a new one of those.
Glenn
mj
11-12-2006 10:24:31
 Re: VAC pto Cover, crank, etc. in reply to GlennFitzGerald, 11-11-2006 16:44:21
I believe that the PTO shield and drawbar are the same throughout the VA Series (VAH & maybe the VAI excepted on the drawbar.) The cranks on the early VAs were specific to the front bolster configuration (i.e.- an adj. WF takes a different crank than the SF). If you go thru the parts book you can telll which fits what.
amo
11-11-2006 17:13:56
I MADE A HAND CRANK FOR MINE, I GOT A 3 FT ROD THAT WOULD GO IN THE CRANK HOLE, BORED A HOLE IN THE END AND PUT A SMALL BOLT IN AND THEN HEATED THE ROD TO GET THE BENDS IN IT. WORK GREAT FOR ABOUT #10.00
