Need help identifying Case Tractor year / model #
~Tami
11-10-2006 17:03:25
Hi, my Father recently bought a Case Tractor and he is trying to find out the year/model #.
On a metal plaque on the dash board is the #480 45 5805. Etched into the casting of the motor are #'s 5650A, 5618A & 5600A ... also on motor is #1211.
Any help would be greatly appreciated.
Thanks,
~Tami
casemand
11-12-2006 16:18:10
 Re: Need help identifying Case Tractor year / mode in reply to ~Tami, 11-10-2006 17:03:25
I would guess the serial nimber should read 480450S instead of 480455805. Serial number is also located on the engine flange bt the air cleaner. That would make it a 44 S. I also have a 44 with the brass brake pedals.
caseman-d
Larry Martin
11-12-2006 07:13:46
Your part numbers are for a SC head and a SC transmission case. I think you have one too many numbers in your serial number and as Camboted stated it is a 1944 SC.
Paul in On
11-10-2006 21:30:15
Usually you'll find the model number on that metal plate that's on the dash there. The number is the serial, but there should be above it? MAybe be faded or rubbed off, but take another look.
~Tami
11-11-2006 00:37:24
 Re: Need help identifying Case Tractor year / mode in reply to Paul in On, 11-10-2006 21:30:15
Thanks Paul, I will have him check the plaque again.
Harry Case
11-10-2006 20:29:11
Hey Tami Could you give us some more clues, how big is this tractor, what color was it ,tire size, wide front or narrow, on steel or rubber or ????? I see nothing in 150 of J.I.Case by C.H. Wendel even close to these numbers. Thanks, Harry
ps. how about a picture?
~Tami
11-11-2006 00:53:25
 Re: Need help identifying Case Tractor year / mode in reply to Harry Case, 11-10-2006 20:29:11
Hello Harry,
The tractor is smaller in size. Color is orange. The brake pedals brass. Also, says JI Case Co. Pacine Wisconsin on it. I will get more details about tires, front end width etc. Working on getting a photo :)
Thanks much !
~Tami
Camboted
11-11-2006 05:01:36
 Re: Need help identifying Case Tractor year / mode in reply to ~Tami, 11-11-2006 00:53:25
The only tractor I know of that used brass brake pedals was one year of S model production. I believe it was 1944. My gues would be it is a 1944 SC.
~Tami
11-11-2006 12:50:44
 Re: Need help identifying Case Tractor year / mode in reply to Camboted, 11-11-2006 05:01:36
Great ! I also found out that the rim are 26in, w/rubber tires & it has a wide front. The clutch is a tall lever hand clutch. I will check out the 1944 SC.
Thanks so much for your help & enjoy your day.
~Tami
Tom Railsback
11-11-2006 16:11:36
 Re: Need help identifying Case Tractor year / mode in reply to ~Tami, 11-11-2006 12:50:44
With the 26 inch rims, I'd say it's an S not an SC. The S was the "standard" or wheatland version. 719 S's were built in 1944 according to production figures I got about 15 years ago.
~Tami
11-11-2006 16:30:25
 Re: Need help identifying Case Tractor year / mode in reply to Tom Railsback, 11-11-2006 16:11:36
Just talked to my Father & he said that the front axel is not straight, but an unside down V.
He is 500 miles away from me, so just getting more info each time I talk to him on the phone. He is real excited about getting the tractor, so he really appreciates the info everyone is giving.
~Tami
Tom Railsback
11-11-2006 05:39:50
Ted hit it right on the nose. With what he said and the 5600A part number, I went to the S parts book and "bingo".
~Tami
11-11-2006 12:55:08
 Re: Need help identifying Case Tractor year / mode in reply to Tom Railsback, 11-11-2006 05:39:50
Excellent, thank you very much for checking.
Sounds like that's the one.
~Tami
Camboted
11-12-2006 04:12:25
 Re: Need help identifying Case Tractor year / mode in reply to ~Tami, 11-11-2006 12:55:08
Tami, An original S with the brass brakes is a rare tractor. Take care of it as it has some value. I doubt if there are many around.
~Tami
11-13-2006 12:49:31
 Re: Need help identifying Case Tractor year / mode in reply to Camboted, 11-12-2006 04:12:25
Thank's alot, it seems to be a 1944 S. Do you have any idea of the value of this tractor? It is in great condition other than fading of the paint. Runs very smooth & seems to have low use. The pedals show hardly any ware. A couple of my Fathers friends are already trying to buy it from him, one guy offered $2,500. I feel it may be worth alot more. Any thoughts ?
