CASE SC
BOBTOM
11-09-2006 21:37:03
I have a sc need to know the location of oil check level in the rear end on this tractor I have two pipe plugs below the seat on the left side from the rear I also have a powerlift on the rear . can not find a place to check the level on trans or the powerlift Thank you SUPER H BOB
C. Amick
11-13-2006 09:05:03
 Re: CASE SC in reply to BOBTOM, 11-09-2006 21:37:03
I believe the levels for both the transmission and the lifting bail (powerlift) are checked on the right side of the tractor near the rear. There should be one level plug for each compartment.
BOBTOM
11-11-2006 20:29:12
I have case sc need to know how check rear end for oil,it also has a powerlift also there are two pipe plugs under the seat. Need know were the to check the level of the rear end and the powerlift oil thank you bobtom
C. Amick
11-13-2006 09:18:12
 Re: CASE SC in reply to BOBTOM, 11-11-2006 20:29:12
Have you seen the web site below? You can find parts catalogs for almost any old Case or Farmall.
