DC tire pressure
joe netx
11-09-2006 19:10:07
What tire pressure should I use on 13.6 x 38 tires on a 1950 DC for general use with the rear weights.
SpeedySteve
11-10-2006 22:52:04
 Re: DC tire pressure in reply to joe netx, 11-09-2006 19:10:07
My Original Factory Book calls for 12#'s in the Rear, and 28 in the smaller front tires. I run my tires w/weights on the front tires, and I also put calcium chloride in them. The book says to put 4 #'s more pressure in the furrow tire if you are plowing. Here in Idaho there isn't much flat land but I don't think this matters. You are supposed to have 4 #;s more pressure in the furrow tire according to the manual. Hope this helps. Best regards.
Joe netx
11-12-2006 17:29:04
 Re: DC tire pressure in reply to SpeedySteve, 11-10-2006 22:52:04
Tanks so much, I've been putting to much air in my tires. I've been putting in 18 lbs. That's probably hard on the tire.
Walt Davies
11-10-2006 15:09:36
12 to 14 lbs should be sufficiant. it all depends on use just driving around the shows 14 would be alright. But if pulling a heavy load you may have drop it some. Even letting one tire run slightly under another to get even traction. But not over 14 that would be too hard on tractor and tire.
Walt
DurangoCase
11-10-2006 08:26:52
I'd always been told one pound per inch of width.
Glenn F.
11-10-2006 13:37:12
 Re: DC tire pressure in reply to DurangoCase, 11-10-2006 08:26:52
That principle is opposite as you sure wouldn't put 23 lbs. in a 23" wide tire.
DurangoCase
11-10-2006 18:22:10
 Re: DC tire pressure in reply to Glenn F., 11-10-2006 13:37:12
Real good rule of thumb on rear tires 10 to 14 inches though.
