Changing 49 VAC from Trike to Wide Front
n2deep
11-08-2006 17:25:01
I moved from the desert to the woods, am considering changing to a wide front. Has any one done this job before, would you recommend it or would you just buy another tractor? Suggestions, comments welcome
Jerry W
11-09-2006 13:19:18
 Re: Changing 49 VAC from Trike to Wide Front in reply to n2deep, 11-08-2006 17:25:01
If you are going to change to an I beam adjustable front it is very easy and just a matter of removing one and attaching the other. If you are changing to a non adjustable wide front then you also have to change steering box as a reverse action is needed. It would be just about impossible to change to the later tube adjustable front as used on mid 1951 and up tractors.
Jerry
Dave Taylor
11-08-2006 19:00:23
At the price of VAC"s if you want a wide front end tractor it sounds like a good reason to look for another tractor. You may end up with as much money and your time in the conversion not mentioning the problems you may run into. I don"t know the price of VAC"s in your area but around my area you can get a good one for $1000 - $1500. I know of a complete VA locked up and bad tires for $375.
N2deep
11-10-2006 17:55:22
 Re: Changing 49 VAC from Trike to Wide Front in reply to Dave Taylor, 11-08-2006 19:00:23
Dave
Is it a wide front? If so Where id the little raskel located, I live in Maine but will travel for the right deal.
Thanks
Art
