VAC Bearings
Glenn FitzGeral
11-08-2006 13:56:55
I have never had any experience with a VAC. Do they have insert rod and main bearings? Are complete overhaul parts still available/easy to obtain? Another question: The fellow I'm buying my VAC 14 from (out of state) tells me it either needs a clutch adjustment or replacement. Are VAC's particularly noted for having clutch trouble? Are clutch parts still readily available?
Thanks, Glenn
C. Amick
11-09-2006 09:20:47
 Re: VAC Bearings in reply to Glenn FitzGerald, 11-08-2006 13:56:55
I've lost the lining off the clutch plate a couple times. The last time I had it relined, the shop drilled some extra holes and put in some extra rivets. I've also seen parts break on the fork that disengages the pressure plate. If you can't find a new part, I'm sure you can find a used one. New piston and sleeves sets are available. New rod bearings are available from standard to +0.040". I know that main bearings are available in standard, 0.010" and 0.030".
Phil Lang
11-09-2006 15:57:24
 Re: VAC Bearings in reply to C. Amick, 11-09-2006 09:20:47
Regarding the clutch trouble, what were the symptoms of the broken clutch fork? Thanks.
C. Amick
11-10-2006 09:04:06
 Re: VAC Bearings in reply to Phil Lang, 11-09-2006 15:57:24
As well as I remember the clutch wouldn't disengage and it seemed as if the clutch plate might be stuck to the flywheel.
Phil Lang
11-10-2006 09:57:59
 Re: VAC Bearings in reply to C. Amick, 11-10-2006 09:04:06
Thanks for the feedback. My clutch isn't fully disengaging either. I was going to order new clutch parts, but I think I'll disassemble first. It was suspicious because the clutch never slipped.
Jerry W
11-08-2006 17:26:00
VAC's have insert rod and main bearings that are mostly available but in some oversizes there is a delay while manufacturers get minimum quantities. I don't think they have any more clutch troubles than any other tractor.
Jerry
Glenn F.
11-08-2006 18:11:44
 Re: VAC Bearings in reply to Jerry W, 11-08-2006 17:26:00
Thanks Jerry, for your quick responses. I may need to e-mail you at times when I get the little tractor home.
Glenn
