Case LA Axle Seal Replacement Part?
StuckRusty
11-07-2006 15:33:02
The rear axle seals on it now are a NATIONAL 15015 but my local NAPA store said it was an obsolete part and unavailable. What are LA owners using instead? The LA has hydraulic brakes if that makes any difference.
BarryfromIA
11-09-2006 19:12:00
 Re: Case LA Axle Seal Replacement Part? in reply to StuckRusty, 11-07-2006 15:33:02
Is it possible to take the seal to the Motion Ind store? I have had some luck with that approach when I needed a seal for an older Electric Wheel Co. wagon gear.
rusty tractors
11-07-2006 16:12:35
According to my interchange catalog it should be CR #15005, or Fel-Pro #19062. I would check the dimmensions first as I have found that it is not always 100% accurate
BarryfromIA
11-07-2006 17:28:36
 Re: Case LA Axle Seal Replacement Part? in reply to rusty tractors, 11-07-2006 16:12:35
Try Motion Industries.
StuckRusty
11-08-2006 03:12:11
 Re: Case LA Axle Seal Replacement Part? in reply to BarryfromIA, 11-07-2006 17:28:36
Thanks guys. I checked Motion Industries and they do show the seals in stock but I will also check the other numbers and compare.
StuckRusty
11-08-2006 09:41:37
 Re: Case LA Axle Seal Replacement Part? in reply to StuckRusty, 11-08-2006 03:12:11
Just checked on those seal numbers and learned they are wrong. Both refer to a much smaller seal. I guess I will keep looking.
