SC Zenith Carb Drain Plug
Gobind
11-07-2006 05:35:39
My '54 Case SC lost its carburetor drain plug and I'm hoping y'all can advise me on a replacement. It's a 09658AB Zenith carburetor and my parts manual lists the plug as part number CT91-3 plug, bowl drain (1/8" pipe). I tried the obvious, using a 1/8" galvanized steel plug from the plumbing section of the local hardware store, but the threads don't match. Anyone know the exact diameter and thread for this carburetor drain plug? Thanks in advance.
RustyFarmall
11-07-2006 14:20:50
 Re: SC Zenith Carb Drain Plug in reply to Gobind, 11-07-2006 05:35:39
The 1/8" pipe plug should work, although the original is probably brass, the threads are still the same. Maybe the threads in the carb bowl are messed up?
Jheitkemper
11-07-2006 06:44:22
Any Hardware or Auto Parts store should have a brass pitcock that will fit ,,,a fine thread bolt works well in one of mine <,,My Dad widdled a stick and brought them back from the hill before ,, good luck, Jim
