VAC 14 Weak Spots...?
Glenn FitzGeral
11-06-2006 03:39:05
I'm buying a VAC 14 over in Michigan, 460 miles from here. The fellow has sent me pictures, and patiently answers every detailed question I ask. Neither of us are particularly familiar with VAC's. Are there any particular weak spots/areas of concern I should be looking out for? Where are the most likely places the casting may be welded? He says he does not see any welds anywhere. The tractor is a '54, is complete, and in good operating condition. Everything works but the temperature guage. It starts up and runs very nicely, holds 12-15 lbs. oil pressure, and does not appear to use any oil. The transmission is quiet in all gears. There is about 1/2 turn of play in the steering. He says it appears to be in the gear box. Can this likely be fixed by adjusting or will it need new parts? I appreciate ANY input you have for me.
Glenn FitzGerald
mj
11-06-2006 16:00:18
 Re: VAC 14 Weak Spots...? in reply to Glenn FitzGerald, 11-06-2006 03:39:05
Click the link and click to enlarge--
Jerry W
11-06-2006 05:47:00
Basically they are a solid little tractor. If they ever have been frost broke it will be behind the carburator. Hood will rot out around the front seam. With a lot of hours the linkage for the governor and throttle will wear. Mice like to fill the toolbox up with "stuff". Later wide fronts usually have been welded if they got worked.
Jerry
