Broken Stud Bolt
Minn Norske
11-06-2006 02:36:50
This is on a 930 The 2 bolts holding the back part of the wide front on! One fell out & the broke off up in the casting it"s a #8 stud with locktite on it.How does one get the rest of the stud out? Need suggestions (asap) Thank You
GeoMo
11-07-2006 05:07:19
 Re: Broken Stud Bolt in reply to Minn Norske, 11-06-2006 02:36:50
I have removed several broken bolts.
I bought left handed drill bits. Several times when drill breaks through bolt it will catch and spin the bolt out.
I also bought a set of extractors, they are concaved tapered square.
Drill specified hole in the center of broken bolt, drive extractor into hole and turn out.
I have best luck by not using too large of extractor so as not to distort threads.
A little luck alwasy helps.
c hess
11-06-2006 04:51:52
Heat bolt with torch hot as you can-let cool- Do not squirt oil or water on to cool it as this will again make it hard When cool you should be able to drill hole -than try a easy out make sure you are in center of bolt when you drill!!! You might have to eventually drill whole bolt an re tap. Good luck
