400 air intake hose
Tuggle
11-05-2006 21:09:09
Howdy all,
I have a 400 and the previous owner installed a flexi alumunim pipe on the breather. It is now cracked open.
The angle is so sharp from the oilbath to the carb, I not sure what to use.
Any idea????
INCase
11-06-2006 13:47:48
 Re: 400 air intake hose in reply to Tuggle, 11-05-2006 21:09:09
I presume you are talking about the large 55-57. This may not help if you don"t have the right carb. but the 400"s sucessors, the 700-800"s had an aluminum pipe that was cast to work between the air cleaner and the carb. MUCH better design than the hose idea. The trick is to have a carb that you can bolt the air cleaner to. The next trick is to find a tube.
Curt Cooke
11-06-2006 13:25:27
I have a 400LP that someone had replaced the Ensign carb with an Impco and had the same problem. I used PVC elbows and straight hose pieces to make that miserable connection. I did paint the PVC black so it looked OK.
Tuggle
11-06-2006 21:03:40
 Re: 400 air intake hose in reply to Curt Cooke, 11-06-2006 13:25:27
PVC ?? what a good idea, Thanks
