dc engine problem
keith52
11-05-2006 08:26:17
I have a 1948 dc it was rebuilt a few months ago. the problen i have is that it is fluttering. I have checked the valve and checked intake for leaks have found no problems. The only thing that helps is if I swich the number 2 and 3 cylinder wires. I have checked mag to be sure it is top dead center when putting wires on. EVERY THING SEEMS OK. But it still flutters. If anyone has had this problen or knows what is wrong it would be very helpfull. Thanks for all your help
Keith
Walt Davies
11-04-2006 14:34:09
 Re: dc engine problem in reply to keith52, 11-05-2006 08:26:17
Sounds a little like you need to adjust the governor linkage to specs. Hold you hand on on the linkage and see if it takes the flutter out.
Walt
