Case 430/530 frame
Kevin5456
11-03-2006 12:39:31
Is the Case 430 frame the same size as the Case 530?
Tom (Ks)
11-04-2006 07:59:48
 Re: Case 430/530 frame in reply to Kevin5456, 11-03-2006 12:39:31
Thr frames on the diesels should all be the same, the height to the top of the hood will be different from a 430 to a 530.
J heitkemper
11-03-2006 20:56:45
Honestly ,I do not know ,But I would be willin g to bet the 430 ,530 ,630 , share the same wheelbase ,, Block ,starter,rearend componets , With minor changes ,,probably ,differences occur in radiator cooling size , Diesel fuel pump settings ,,Valve size , and bore in the block itself , CASE in point , my Dad Bought new 1966 430 DemonstratorDiesel , about 1975 it finally needed an overhaul ,, When I got the Sleeve assembly ,parts from Case ,they literally fell thru the engine block ,, To my amusement took Them back to the egotistical parts man ,who is always right ,,Who insisted I made a mistake ,,At which time I told him this was a Demonstrator ,in a few Days He had the right parts ,And Naturally he was right and I was wrong,because I did not tell him what I REALLY had , And He would not tell me what he gave Me Either , His attitude was ,Just take this stuff with you KID ,and shut the H--- Up ...Dad and I suppose We have 630 sleeves , not sure about the Pump ,This little 430 would eat a MF 175 diesel alive ,And hold its own with a 4020 gasser that had 4/16s behind it , Before the big JD came to the farm and notill . My brothers and I can recall plowing with 3 /12s around the clock 24 /7in shifts with this fuel mizer and running up 200 hours just like that for another oil change . What a Tractor , 1st high ,or 2nd and 3rd direct with traction lock thru the tough spots depending on the soil ,, Dad's 92 now ,and he still owns this little Buster ,it keeps him young ,I had to find my own 430 ,Just a straight stock model ,but nice all the same ,Thanx For reading ,Jim
