Water in DC
Keevin
11-02-2006 10:01:39
Is there any place to drain the water out of a DC other than the bottom of the radiator. I can't find a drain on the block any where.
Thanks
L.Lamp
11-02-2006 20:05:25
 Re: Water in DC in reply to Keevin, 11-02-2006 10:01:39
There is a 3/8" pipe with a cap near the left side of the tractor near the bottom of the radiator. That drain will empty everything. It is on the carburetor side of the tractor.
Dale L
11-02-2006 15:45:48
If I remember correctly there,s a small pipe plug under the water pump to drain out the water pump "cavity".
dboll
11-02-2006 12:54:33
that will drain them adequately
Keevin
11-03-2006 08:38:15
 Re: Water in DC in reply to dboll, 11-02-2006 12:54:33
Thanks a lot...
