1070 powershift
jaker2
10-31-2006 09:59:56
I have spotted a 1070 powershift fender tractor that needs transmission work. The engine starts and runs good. It was supposedly overhauled less than 200 hours ago but has not been used much in the past 6 years. The metal is pretty good, been repainted at some point in its life. The rear tires are about 50 percent with light cracking. What is the tractor worth?
I have a 1030 that has a good rear end but a bad engine. Would it be worth my efforts to put the 1070 engine in my 1030? BTW,the 1070 engine has a blower. Will the 1030 flywheel and clutch work on the 1070 engine?
Nedd
10-31-2006 10:38:37
 Re: 1070 powershift in reply to jaker2, 10-31-2006 09:59:56
Not 100% sure but the flywheel and clutch should work, both are 451 engines with the same crank. Check the 1070 block to see if it has the hole in the casting for the steering from a 1030. Some early ones did but I have heard of several people just boring that hole with no problems. fuel lines are on opposite sides. As is ehxhaust and intake. Where are you located?
