case dc4 lp
jason210
10-30-2006 20:07:56
Greeting all, just located a 52 Case DC 4 LP, with 80% rubber, in great running condition (per the current owner), no 3 point, but has hydraulics, factory LP, is all there and straight, older paint. Wondering what a tractor like this is worth? Not a whole lot information out there on the LP models. I have a JD 720 and JD 520 LP and enjoy them, but need to expand my color selection. Thanks in advance.
Walt Davies
10-30-2006 20:46:36
 Re: case dc4 lp in reply to jason210, 10-30-2006 20:07:56
I would say around $1000 to $1500 is the going price range depending on the condition. drive and look it over real good there could many hidden problems. Let it run at at idle for a long time or work it hard to make sure it doesn't run hot. If its Ok it should not get over 160 with the shutters open at idle and maybe 190 or 200 if under a hard load. look in the radiater to see if the water is circulating it should look like a river if Ok.
check for body work and how much is rusted out and dented or burned out around the exhaust..
Check the front end and steering for sloppy joints. they are not real tight when new but should not be so loose as to be hard to control the steering.
Walt.
