Case plow
Scott KY
10-30-2006 18:54:08
I found a nice 3 bottom hydraulic lift Case plow for sale. I think it is a CHA model. It has the box beam across the top. Anyhow, it is in good shape except the molboards are worn bad. I can get new ones from Shoup but they are $94 a piece. Does anyone know of another source for moldoards? Has any one tried building up worn moldboards with weld and grinding them back down?
M5G
10-31-2006 04:43:18
 Re: Case plow in reply to Scott KY, 10-30-2006 18:54:08
This will tell you how old I am.....
My dad use to add to the bottom of a worn plow by heating up two pieces he preformed using his blacksmith forge...and heat them to right temp and hammer-weld the two into one nice new plow..then he would heat up the edge and use his hammer on the anvil and make a nice edge which was later sharpened by file. So my answer would be yes--and probably much easier with today's tools. Good Luck..and always have fun!
