continental engine or case engine
darrell in rr
10-29-2006 23:11:10
how can you tell if you have a continental engine or a case engine.
its a case vac 1948
thanks
Joe (Wa)
10-30-2006 07:45:16
 Re: continental engine or case engine in reply to darrell in rr, 10-29-2006 23:11:10
1948 with original engine is Case built. Engine serial nr is stamped on the block above the starter near the cylinder head, hard to spot sometimes, will start with letters VAB or VAC if original engine. Overhead valve cylinder head, raised casting nr VT148 or VT159 on top outside valve cover, manifold side if I remember right.
Joe
Graham in NZ
10-29-2006 23:28:42
Don't quote me on this, but my rusty memory seems to tell me the Continental engines were side valve flat head and the replacement Case built engines were OHV.
