SC water leak
Ralf from MI
10-26-2006 16:49:32
Just bought a nice SC on a sale, tractor just had a valve job and all the tin is in great shape. The only thing I could find wrong was the water pump was leaking. When we got her home and unloaded we found that driving around it doesn't leak, BUT as soon as you shut it off it leaks (and buy leak I mean a small stream about pencil lead size ) Anybody out there have a take on this?
Tom Brzezicki
10-29-2006 06:40:13
 Re: SC water leak in reply to Ralf from MI, 10-26-2006 16:49:32
Sounds like mine. Pretty much same situation Got mine at an auction and it leaks. The waterpump needs to be rebuilt. Napa will do it for about $75
Ralf from MI
10-27-2006 17:10:47
Thanks guys, The rad. is correct with the winged cap. The guy was selling it told me the tractor had been sitting in a shed for 15 yrs. When I get some free time I'll take the pump off and check it out. If it don't stop raining that may be sooner than later. Thanks again
John Saeli
10-28-2006 06:09:04
 Re: SC water leak in reply to Ralf from MI, 10-27-2006 17:10:47
We stock an SC water pump kit here. Very reasonable.
Walt Davies
10-27-2006 11:06:29
it is possable then that it still has the old leather seal these were not very good and would leak a lot when setting. You could easily replace the seal with a new one and check for slop in the bearing at the sametime. any bearing shop can get you a replacement seal if you take it in to them.
Walt
C. Amick
10-27-2006 09:42:50
I assume the radiator is correct and you do not have a pressure cap on it. Is it leaking around the shaft? It seems like SC water pumps are prone to leaking if the tractor has been sitting around for a while unused. If you have to get it rebuilt, you might try O'Reilly Autoparts, if there's one in your area.
Ralf from MI
10-27-2006 08:54:40
Walt my pump has no grease cup, but it dose have a fitting that comes out with a line that loops around to the neck that comes off the engine just below the rad. hose. This has to be for a bypass I assume. Thanks anyway for the reply
Walt Davies
10-26-2006 21:28:47
It should have cup on the top of the pump shaft you put water pump grease in it and sqeese it down every once in while to stop the leak. I got my grease from Lubriplate.com
Walt
