Knocks
Jim Petterson
10-26-2006 16:04:00
What is the problrm when an engine knocks?
Walt Davies
10-26-2006 20:54:42
 Re: Knocks in reply to Jim Petterson, 10-26-2006 16:04:00
Rod bearings, Piston bearings Piston slap something just loose inside.
A small test listen with a long screw driver to locate the knock area. Then pull the spark plug wire for that piston if knock goes away then its the rods if not then its the piston. (Darn i hope i got that correct it been along time since I have had to do that test).
