CaseIH 885??????
Tx Jim
10-26-2006 06:46:33
I asked this question on Today's Tractors with no response so I thought I'd ask here. Anyone have any experience with a CaseIH 885/cab tractor because I'm looking at one to cut/rake hay? Thanks,Tx Jim
RobertTX
10-26-2006 13:45:29
 Re: CaseIH 885?????? in reply to Tx Jim, 10-26-2006 06:46:33
I have a 585, which I believe is same transmission, hydraulics, and rear drive. It can be a little slow to shift 1-2-3-4, and the range change or shuttle can be balky. Other than that, it is very nice tractor. The engine is the German "Neuss" engine which has an excellent reputation. Mine does not have TA, and I do not think the 885 does either. If I am incorrect, my apologies to the other poster. I thought TA went away when the x74 series came out.
Tx Jim
10-26-2006 14:23:10
 Re: CaseIH 885?????? in reply to RobertTX, 10-26-2006 13:45:29
The 885 I drove has an electric operated hyd Hi-Lo. Maybe not a TA but favors one. Thanks,Jim
richard in nz
10-26-2006 23:07:35
 Re: CaseIH 885?????? in reply to Tx Jim, 10-26-2006 14:23:10
Good all-rounder, may have T/A it was an option, will last ok as long as you dont use it as a splitter on the road when towing heavy trailers. A later 885 will have the better Rockford clutch and may have the later type parking brake too. If it is 4WD stay away from those with the Japaneese front axle, most have the centre drive ZF axle which wont give much trouble if any.
PhilcaseinWPa
10-26-2006 10:00:49
I have a CIH 885 open station. 72 hp, good strong engine, transmission can be a pita as well as the TA and hydralics. My transmission troubles have mainly been either linkage or trouble with the TA not shifting one way or another. Used to not shift into the TA It has an electric switch that operates a hydralic valve to put the TA on I think. Had that fixed. Then had to get a new hydralic pump. Now it won't stay in the high side of the TA when pulling hard like plowing. Works ok any other time. I still like the tractor, would like it better if it had a cab and fwa, but that would also be more to go wrong. I like my Case 630, every control is mechanical but the 885 is more comfortable.
Phil
BCnT
10-26-2006 08:31:58
i'm new to the Case brands but i've got a Case David Brown 885 if thats what youre wanting to know about...not sure CIH made a 885...if they did nebber mind.
as far as hay work it should do about anything ya wanna do shy of runnin a big round baler...good heavy tractor with decent power...hydraulics can be a RPIA if ANY dirt gets into system.
PhilcaseinWPa
10-26-2006 10:02:09
 Re: CaseIH 885?????? in reply to BCnT, 10-26-2006 08:31:58
CIH 885 is a completely different tractor. It is really the same as an International 884.
