Case SC 12 volt Conversion
hayrookie
10-26-2006 02:58:00
I just bought a 41 Case SC. The previous owner started the conversion, but never finished. It has a one wire alternator already installed. I just need to know where to connect that one wire to. I assume I will also need to connect the battery "-" to ground and "+" to the starter switch. Then another wire from the starter switch to the starter. I'm guessing I don't need to run anything to the mag because all I do now to start it is jump the starter with a 12 volt battery to start it then it runs fine.
C. Amick
10-26-2006 09:22:38
 Re: Case SC 12 volt Conversion in reply to hayrookie, 10-26-2006 02:58:00
Look in the Research & Info. "Articles" on this web site and I think you will find the information you need.
