Rust in fuel tank
Joe C
10-25-2006 18:07:01
I took the tank off today to inspect and clean. It is solid and straight, but full of crud. What are some good ways to clean the rust, dirt, and crap, out so my fuel will flow freely once again? I plan on sealing it when I get done, so I want to do it right the first time. Thank you all.
Joe C
10-26-2006 19:08:49
 Re: Rust in fuel tank in reply to Joe C, 10-25-2006 18:07:01
Again, Thank you all!
keith52
10-26-2006 12:20:24
I HAD RUST IN A FUEL TANK ON MY DC. I PUT KEROSENE IN AND A HEAVY CHAIN WORKED IT AROUND. THEN EMPTIED OUT AND PRESSURE WASHED IT CAME OUT FINE. GOOD LUCK
Walt Davies
10-25-2006 23:41:45
I put a gallon of kerosene and a lot of sand and gravel in one then shook it around a lot then poored the kerosene off then used my power washer to flush it out. did a pretty good just in very short time. Get two big kids to do the shaking.
Walt
Tom Railsback
10-25-2006 18:37:35
If you have access to an engine rebuild shop, see if you can get them to hot tank it for you. Then put in tank sealer.
