Part for COM 400B
BobV
10-25-2006 08:03:55
Can anyone help me for a part on the Hyd. lines leading from the control modual to the filter and Rad.,and back.? This is a nut 3/4" size that fastens the 1/2" lines to the control modual. Case part #81LB in the parts book for 400B, page 22, I've been told that the 600B might be the same.Help!!!!
BobV
10-26-2006 19:13:04
 Re: Part for COM 400B in reply to BobV, 10-25-2006 08:03:55
Don: your the MAN! call you in the morning Thanks!
Don Livingston
10-26-2006 13:31:20
I found them. I have 3. Don L. @ Rusty Acre.
Dave on the San Andreas
10-25-2006 12:28:14
I am looking at the parts manual and can not tell if the nut is a flare or a compression nut. I just went through this on my hydraulic line that goes back to the Eagle Hitch. On my Eagle Hitch, it was 37 degree flare nuts which I purchased from McMaster Carr (watch out for Saturday shipping! They bite real hard and don't deliver!!!). I recommend that you look at their web site and get a look at the various types of tube nuts (both flare and compression) to match it up. At any rate the nut will be a standard of one sort or another. Any good hydraulic shop or hardware store could have the correct nut also. If the tube is too short to cut and place a new nut on, then you will also need to replace the tube and the nut at the other end. Full replacement is what I went for since this is the high pressure link between the control valves and the lift. On the COM colling system, the pressure may not be quite so high, and therefore they may have used 45 degree flared fittings or compression fittings. For the same situation on old automatic transmission cooling connections to the radiator of a car I remember 45 degree flares were common. When you install the new fitting, be sure the surface of the mating fitting is clean and that the tubing goes in very straight! There is lots of information on the web that is put out by home aircraft builders and race car mechanics pertaining to the subject of hydraulic line fittings if you want to make it a research project.
Hope this helps
Dave
BobV
10-25-2006 13:50:43
 Re: Part for COM 400B in reply to Dave on the San Andreas, 10-25-2006 12:28:14
Dave: Thanks for the reply I'm going to try and anything else got to get it back together!
