case 430 left brake catching
kdok44
10-24-2006 18:19:27
Hello i have a 1969 case 430 its a good little tractor but recently the tractor has been lurching as i am either letting the clutch out or when i push the clutch in, It will lurch to the left as if the left break is catching. Once the clutch is fully out its fine makes it kinda hard moving bales.. I noticed with the tractor off if i push in the left brake the clutch will drop. or if i push in the clutch the left brake will drop. Does anyone know whats going on here or a fix for it thanks
kdok44
10-26-2006 06:13:04
 Re: case 430 left brake catching in reply to kdok44, 10-24-2006 18:19:27
Hi yeah its probably caused by the transmission leaking it must have a leak higher up cause when i top it up it leaks pretty good. once it sits for awhile not bad then once it leaks out to a certain spot it barely leaks but still is 3/4 full or better so i am not running it dry. Well thanks for all the help iam going to try some of that lucas hub seal i ll let you know how it goes as for the brakes i ll prob wait till spring to tackle that one ttyl..
J Heitkemper
10-24-2006 18:31:31
Have YOU EVER greased this tractor ?...
kdok44
10-24-2006 18:41:01
 Re: case 430 left brake catching in reply to J Heitkemper , 10-24-2006 18:31:31
well i just got the tractor about 5 months ago The guy i got it from said it was all greased up but maybe he missed a few. there are grease nipples on the pivot point of the clutch and the brakes do u think it could just be dry and that is making it grab
J,heitkemper
10-24-2006 19:21:35
 Re: case 430 left brake catching in reply to kdok44, 10-24-2006 18:41:01
Easy fix then ,,This one may be so bad that it may be best to take out the zerk and squirt wd 40 or equal in there to get it freed up 1st. ,,.Just curious ,Gasser or Diesel ?
kdok44
10-25-2006 05:38:29
 Re: case 430 left brake catching in reply to J,heitkemper , 10-24-2006 19:21:35
hi there its a gas this will probably sound dumb but whats a zerk when i first got the tractor it didnt do this just did it one day and has been doing it since i dont use the tractor very much as we havent got snow yet i mainly use it to move round bales once a month for 10 mins or so. But ive been giving it a good overhaul before winter hits thanks for your help if you have any more ideas
j heitkemper
10-25-2006 20:23:45
 Re: case 430 left brake catching in reply to kdok44, 10-25-2006 05:38:29
From what i understand ,i think that if it were mine ,i would remove the floorboards and take the brakes apart ,,,Probably got a lot of water and rust in there from setting out in the weather ,Might be a job for a local fixxer upper in the family or neighborhood ,, Be careful that you do not break casting s pulling the brake hubs off ,, I have seen tranny oil leak on these brakes ,thereby rendering them useless ,If so clean ,with brake parts cleaner ,,and put a quart of LUCAS Hub Sealer in the tranny ,Not a mechanic in a Bottle ,but with any luck,it will stop the leaks ,Good luck Jim p.s. grease fitting = grease zerk
kdok44
10-25-2006 19:20:10
hi thought u might want to know i got the brakes working better so to speak. I greased it all up and it worked a little better but still did it so i played with the adjusting bolts for brake play and noticed that the brake "actuater"(spelling) on the left had little to know play where the one on the right had a good 1.5 or more inches. and the left side was stuck in an out position i gave it a tap just to see if knocking it back would help. it is still jammed in there but now in the off position. i started it up and it ran fine no lurching in any gear but now i have no left brake where i live is very flat so i very seldom use the brakes but would still be nice to have. Any ideas at least the right one still works if i ever need it thanks for the help ttyl.
John Saeli
10-26-2006 04:27:25
 Re: case 430 left brake catching in reply to kdok44, 10-25-2006 19:20:10
We went through a similar situation with our 630. We completely dissassembled the brake assembly, cleaned everything, & re-installed. Cured all the ills.
kdok44
10-26-2006 06:15:42
 Re: case 430 left brake catching in reply to John Saeli, 10-26-2006 04:27:25
