new owner vac-14
j stice
10-24-2006 17:10:46
hello all. i just purchased a vac-14 late w/down elbow that supposedly runs i have gotten spark to plugs so far, but spins slow even w/new 6volt. my question is, there are holes in exh manifold i can see at elbows[maybe some i cannot?]and need a used one,BUT hate to spend if cannot verify the eng cond? same with poss convt' to 12v .i tried preloading some start fluid in the cyls but holes may prevent proper atmospherics mixture movement.189 new is steep for guessing.thank you
j stice
10-25-2006 11:58:01
 Re: new owner vac-14 in reply to j stice, 10-24-2006 17:10:46
thanks to all for help/encouragement!
today it got a tune up and new coil. i put the spare starter on it and it spins better, but the threaded stud for cable will not tighten and is prob why its not on tractor.all cables hd and new prior to me. nice blue spark, starter fluid into carb, nothing,lol.will some kind of brush kit for case have a stud as well as brushes and bearing?
the closest case to me in in next state,delaware.
one thing tho, spinning no2 starter while holding cable/stud for connection it didnt seem any more inclined to start than yesterday. i say this as it was being used till ownr passed so the more i get up into" is the timing right? etc" questions, i am prob barking wrong tree as visibly can tell distr not moved for decades[centuries?] lol.
"Endeavor to Persevere"
Jim - Oregon
10-25-2006 10:43:12
It is likely the battery ground. After 50 plus years, it is probably corroded, and makes for a poor connection/circuit. The ground strap for the battery connects to a bolt on the dash. The circuit has to pass through the sheet metal and finally to the starter.
On our VAO, we took a H-D cable and ran it from the bolt on the dash to one of the bolts that holds the starter to the bellhousing. It made all the difference in the world. Now there is a direct connection from the positive terminal of the battery all the way to the starter.
C. Amick
10-25-2006 09:35:50
Could be the push button on the dash. Sometimes the contacts in it get corroded. I assume that you have checked your battery cable (should be Size #2 or #1) connections including the ground. You can crank it over by jumping 12 volts to it right at the starter. The 12 volts shouldn't hurt the starter. Most people keep their 6 volt starters when them convert to 12 volts. If the holes are in the exhaust manifold and not the intake manifold, they shouldn't effect anything.
Jerry W
10-25-2006 08:30:59
I have seen holes drilled in the bottom of exhaust manifolds before. I can only assume it was to drain water before it got into the engine.
Cannot not imagine how it could affect engine starting or short term but noisy running.
Jerry
j stice
10-24-2006 20:21:33
thank you for reply. i will be adding new tune up items tommorow first. also, the tractor came with an additional starter,BUT the one on would be my guess as the "replacement" not the loose one,tho owner is longer here to tell.will prob change to see.then pull last resort.if you feel the manifold could be affecting start? would an old style be ok to use? i saw one for 40 if cannot find later kind.this my first case and after reading 17 pages of forum here looks like there's some really knowledgable folks here.thanks
Roger300
10-24-2006 19:07:42
Your starter may need new bushings, allowing the armature to drag on the field coils, do you have a way to pull start it to see how it runs before switching to a 12V system. Roger
