LP LA procedure for starting
jary
10-24-2006 07:35:07
I'm the happy new owner of a '52 LA with propane. There are 2 valves on the LP tank, one above the other. Do I open them both to start?
jary
10-24-2006 10:53:35
 Re: LP LA procedure for starting in reply to jary, 10-24-2006 07:35:07
Thanks for the info!
big jt
10-24-2006 08:17:51
Forgot to clarify.
Just open the liquid unless is is real cold. Then just open the vapor until warmed up then switch.
jt
big jt
10-24-2006 08:16:08
Lower is liquid withdrawel, Upper is Vapor.
Normally you don't need to use the vapor.
Vapor is to warm up the engine so the vaporizer has enought hot water to do it's thing.
Don't get excited if you see a little frost where the fuel enters the vaporizer this is normal.
jt
Engineer20
10-24-2006 08:14:25
Look closely next to the valves. One says VAPOR and the other says LIQUID. You only need to open one. Mine seems to start easier on VAPOR.
jal-SD
10-24-2006 08:11:22
If they are the same as the factory SMLPG we had when I was a kid, the top valve provides vapor to the carb & bottom one is the liquid valve. The starting procedure for that tractor was to open the vapor valve, start the tractor on vapor & then open the liquid valve after it was running. That old SM was hard to start when it was below 0, the 6V had a hard time cranking it over, wish we'd have converted it to 12V. Had to be plugged in just like a SMD, but once it was running, it never coughed or choked. (My $0.02 worth. jal-SD)
