400b weight
INCase
10-24-2006 06:10:04
What is the weight (dry or with fluids) of a 58-59 Case 400B (small 400 w/COM)? Thanks.
Joe (Wa)
10-25-2006 01:57:39
 Re: 400b weight in reply to INCase, 10-24-2006 06:10:04
From 300B-400B Tractors Operators Manual JI Case Rac. form 9-472
Approximate weight (standard tractor)
411B general purpose, dual front wheels .. 3902 lbs.
411B general purpose, adjustable front axle .. 4076 lbs.
410B Utility tractor .. 2918 lbs.
Joe
Glenn FitzGerald
10-24-2006 09:47:46
I asked this same question (now on p.3). COM utility=3509 lbs., tricycle=3902 lbs. This information was taken from the North American Dealers Association book.
Glenn F.
INCase
10-24-2006 11:24:43
 Re: 400b weight in reply to Glenn FitzGerald, 10-24-2006 09:47:46
Thanks. I see that post now. I'm surprized the tricycle is heavier. I would have figured the opposite.
Tom (Ks)
10-24-2006 18:12:50
 Re: 400b weight in reply to INCase, 10-24-2006 11:24:43
The tricyle tractor had 12.4 X 36 tires and the wide front had 11 X 24 tires. What you lost on the front end, you gained on the rear wheels.
